Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Session has expired or is invalid?
2 REPLIES 2
emluv
1866 Views, 2 Replies
I have a Mapguide Enterprise 2011 Fusion map on a Windows 2008 R2 server that is continually getting stuck or stalling when someone tries to access the map. In order to fix the issue, I do a complete reboot of the server and that does the trick, however, this is not ideal. In the Error.log I get the following information when the map is inaccessible:
<2011-08-30T08:22:36>  2192 Fusion Viewer 70.97.113.229
 Error: Session has expired or is invalid. Please log in again.
 StackTrace:
  - MgSiteServiceHandler.ProcessOperation() line 83 file d:\build\grandprix\build_53.5\ent\os\server\src\services\site\SiteServiceHandler.cpp
  - MgOpAuthenticate.Execute() line 107 file d:\build\grandprix\build_53.5\ent\os\server\src\services\site\OpAuthenticate.cpp
  - MgServerSiteService.Authenticate() line 709 file d:\build\grandprix\build_53.5\ent\os\server\src\services\site\ServerSiteService.cpp
  - MgSecurityManager.Authenticate() line 224 file d:\Build\GrandPrix\BUILD_53.5\Ent\OS\Server\src\Common\Manager\SecurityManager.cpp
  - MgSessionCache.GetSessionInfo() line 175 file d:\Build\GrandPrix\BUILD_53.5\Ent\OS\Server\src\Common\Manager\SessionCache.cpp
Does anyone have a solution to this, I am getting tired of having to constantly restart the server.
Thanks in advance!!
Emily
emluv
2 REPLIES 2
Daniel.Du
in reply to: emluv
Is this thread related?
http://forums.autodesk.com/t5/Autodesk-MapGuide-Enterprise/MapGuide-Server-Goes-Down-Often/td-p/3038...
Daniel Du
Developer Technical Services
Autodesk Developer Network
emluv
in reply to: Daniel.Du
Daniel,
Yes, the threads are related. I posted this beofre I saw the other thread.
I have tried almost everything and still no luck getting Mapguide to stop periodically stalling.
I added a $featureReader-->Close(); to some code I had and it still is stalling. I have attached the code, do you mind taking a look and seeing if I missed something?
I am desperate to get this fixed, any help would be greatly appreciated!!
Thanks, Emily
emluv
