Infrastructure Map Server General
Valued Contributor
Message 1 of 5 (784 Views)
Server not available Error
784 Views, 4 Replies
11-28-2012 08:08 AM
Hi there,
Recently AIMS 2013 always popup this error(see below image). But the map still there, all the functions still work after you click the "OK" below.  Can anyone help me with this?
Valued Contributor
Message 2 of 5 (757 Views)
Re: Server not available Error
11-30-2012 09:16 AM in reply to: swimming123
I also check the error log, it shows following information:
<2012-11-30T10:07:07>     3532    Fusion Viewer    ::1    Administrator
 Error: An exception occurred in FDO component.
        Unable to resolve the host. Host not found.
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation() line 83 file d:\build\ims2013\build_52.8\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpGetIdentityProperties.Execute() line 112 file d:\build\ims2013\build_52.8\ent\os\server\src\services\feature\OpGetIdentityProperties.cpp
  - MgServerDescribeSchema.GetIdentityProperties() line 1261 file d:\build\ims2013\build_52.8\ent\os\server\src\services\feature\ServerDescribeSchema.cpp
  - MgServerDescribeSchema.DescribeFdoSchema() line 278 file d:\build\ims2013\build_52.8\ent\os\server\src\services\feature\ServerDescribeSchema.cpp
  - MgFdoConnectionManager.Open() line 334 file d:\build\ims2013\build_52.8\ent\server\src\common\manager\FdoConnectionManager.cpp
  - MgFdoConnectionManager.CacheFdoConnection() line 1059 file d:\build\ims2013\build_52.8\ent\server\src\common\manager\FdoConnectionManager.cpp
  - MgFdoConnectionManager.Open() line 1051 file d:\build\ims2013\build_52.8\ent\server\src\common\manager\FdoConnectionManager.cpp
The error happens when the server is busy or when you leave the browers without any operation. Why host not found. Do I need to set up something? Thank you.
Valued Contributor
Message 3 of 5 (713 Views)
12-11-2012 11:17 AM in reply to: swimming123
I found this problem only happens for IE; Firefox and Chrome don't have this problem.
Valued Mentor
Message 4 of 5 (705 Views)
12-11-2012 05:47 PM in reply to: swimming123
You are probably using IIS correct?
 Turn off all security on the IIS virtual folder except for Anonymous (I.E. is sending the user)
Valued Contributor
Message 5 of 5 (684 Views)
12-12-2012 08:46 AM in reply to: gluckett
Yes, I use IIS.  Turn off all security is not  Turn off the Authentification, right? Becaue I have to leave Anonymous and Forms Authentification on (for user log in).
You are not logged in.
Ask the Community
