Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Selection point problems when link between Symbols and SDF in MapGuide 6.5
0 REPLIES 0
Message 1 of 1
jama_beta
320 Views, 0 Replies
Hi
I have DWG file contain Point Symbols Bocks and I need to load this DWG to mapGuide 6.5 Author as SDF Not DWG. I export DWG to SDF file also I Export Blocks to BMP image by Autodesk map 2006. I SMB file {Symbol file} using mapGuide Symbol manger also I link between SMB file and SDF using Map Guide Author the point displayed in author as symbols selected successfully but I have some problems in displaying thise problems are
•When I select Feature (point) from SDF layer its sleeted as image object but I need to select the drawing only as blocks in Autodesk map 2006
•When select one feature all feature that’s like in symbol selected feature are selected But I need to select one feature no all
•Displaying of image change when I Zoom out {Some parts of it disappeared}
Your help will be appreciated
Thanks & Regards
0 REPLIES 0
