Solved by reno.sun.gis. Go to Solution.
Solved by gluckett. Go to Solution.
I don't think the map.query is implemented anymore.
http://trac.osgeo.org/fusion/wiki/Cookbook/Map/Query
Instead, you may have to use the Web API to select the object, return the Selected XML and use that to highlight and zoom to the obect.
Finally, I solve my this issue.
I post my solution in the end of the post here: http://osgeo-org.1560.x6.nabble.com/Select-specific-layer-and-feature-by-passing-value-to-flexible-l...
Thank you for your reply 🙂
Hi, I put the solution to the auto-zoom to feature on load for Flexible Web Layouts here (http://mapguide.wordpress.com/2013/06/11/autodesk-infrastructure-map-server-auto-zoom-on-load/)
You can pass:
For example, this selects 2 roads in Sheboygan with an ID or 644 and 684:
The example uses SLATE but it can use any Flexible Web Layout you wish.
Remember, "LOCALHOST" is just a trick to call your own computer as a server, usually you would use the actual name of your server.
For the fusion users, I think this is the simplest solution!
http://autodesk.typepad.com/beyondthebox/2012/09/application-integration-with-autodesk-infrastructur...
If you would like to select features by attribute values 🙂
Moreover, Gordon provided a very neat solution for user would like to select specific layer and feature by primary key too!!!
https://mapguide.wordpress.com/2013/06/11/autodesk-infrastructure-map-server-auto-zoom-on-load/
BTW, I use Gordon's solution for my "Kaliopa Mapguide Mobile Viewer" to allow user select specific features by passing value through the URL.
However, you will face a "zoom to object" issue for point features. Great news is people have already built some solutions for it.
http://osgeo-org.1560.x6.nabble.com/Zoom-to-selected-feature-point-doesn-t-work-td5095926.html
If you're using fusionSF.js like me, you can add the code as following under the renderSelection function:
renderSelection: function (zoomTo, r) {
if (zoomTo) {
var ext = oNode.extents;
//Reno's custom zoom for points
if (ext != null) {
if (ext.minx == ext.maxx) {
this.setExtZoom(ext, 100);
var extents = new OpenLayers.Bounds(ext.minx, ext.miny, ext.maxx, ext.maxy);
this.mapWidget.setExtents(extents);
setExtZoom: function (ext, zoomFactor) {
ext.minx = ext.minx - zoomFactor / 2;
ext.miny = ext.miny - zoomFactor / 2;
ext.maxx = ext.maxx + zoomFactor / 2;
ext.maxy = ext.maxy + zoomFactor / 2;
If you are using "Kaliopa Mapguide Mobile Viewer" with Gordon's solution you will probably would like to add/update following codes under Default.debug.js or Default.min.js:
//Gordon's code
function zoomToObject(sessionId, mapName) {
if (getParam('action' == 'zoom')) {
var SESSION = sessionId;
var MAPNAME = mapName;
var KEY = getParam('KEY');
var ISSTRING = getParam('ISSTRING');
var KEYNAME = getParam('KEYNAME');
var LAYERNAME = getParam('LAYERNAME');
if (KEY != null || KEY != '') {
//The GETSELECTIONXML.php returns the XML of selected features.
var AJAXURL = "/mapserver2014/GETSELECTIONXML.php?MAPNAME=" + MAPNAME;
AJAXURL = AJAXURL + "&SESSION=" + SESSION;
AJAXURL = AJAXURL + "&KEYNAME=" + KEYNAME;
AJAXURL = AJAXURL + "&LAYERNAME=" + LAYERNAME;
AJAXURL = AJAXURL + "&KEY=" + KEY;
AJAXURL = AJAXURL + "&ISSTRING=" + ISSTRING;
var xmlhttp;
if (window.XMLHttpRequest) {// code for IE7+, Firefox, Chrome, Opera, Safari
xmlhttp = new XMLHttpRequest();
else {// code for IE6, IE5
xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
xmlhttp.onreadystatechange = function () {
if (xmlhttp.readyState == 4 && xmlhttp.status == 200) {
SetSelectionXML(xmlhttp.responseText);
ZoomSelection();
MultiGridShow();
xmlhttp.open("GET", AJAXURL, true);
xmlhttp.send();
For zoom problems of point and linear features, modify the code under the ZoomSelection function:
//Modify the extent/zoom level based on your custom needs. You can create some formula for your geographic data :)
function ZoomSelection() {
if (dr.status == 200) {
var env = ParseEnvelope(dr.responseXML.documentElement);
//alert(env.lowerLeft.X + ',' + env.lowerLeft.Y + ',' + env.upperRight.X + ',' + env.upperRight.Y);
if (env != null) {
//var extentSel = new OpenLayers.Bounds(env.lowerLeft.X, env.lowerLeft.Y, env.upperRight.X, env.upperRight.Y);
var sc = (env.upperRight.X - env.lowerLeft.X);
if (sc == 0) {
var pointextentSel = new OpenLayers.Bounds(env.lowerLeft.X, env.lowerLeft.Y - 40, env.upperRight.X + 10, env.upperRight.Y + 10);
var cntL = new OpenLayers.LonLat(env.lowerLeft.X, env.lowerLeft.Y);
map.setCenter(cntL, 1);
map.zoomToExtent(pointextentSel);
else if (sc < 10) {
extentSel = new OpenLayers.Bounds(env.lowerLeft.X, env.lowerLeft.Y - 50, env.upperRight.X, env.upperRight.Y);
map.zoomToExtent(extentSel);
map.zoomToScale(2500, true);
else {
