Thanks Snapple.
I got it figured out...
I ended up just calculating the 'approximate' center of the selected
polygon, and then doing a 'buffer' (selectRadius) around that point.
Thanks again.
Warren M
"Snapple" wrote in message
news:9C0BEFEB604BB31A9F8545F78BA5A4F7@in.WebX.maYIadrTaRb...
> Hi Warren
> Use SDF Toolkit to solve your problem
> step 1: get the extent of selected polygon
> step 2: find polygon within the extent
> These steps are available inside sdftoolkit just use the example there no
> need to crack the brain
> snapple
> "Warren Medernach" wrote in message
> news:D018A2E02C019A556C94A3923A152D6C@in.WebX.maYIadrTaRb...
> > Hello all.
> > I am attempting to do something that I thought would be easy, but I'm
> > struggling a little bit with how to tackle this.
> > - I have a map with 1 polygon layer (Lots)
> > - I want to be able to
> > - select a polygon
> > - from the selected polygon, select all other polygons within a
> > pre-defined radius
> > Any ideas/info would be greatly appreciated
