Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
SdfComponentToolkit and Feature Class
1 REPLY 1
1256 Views, 1 Reply
I program in C # and I use the dll sdfcomponenttoolkit. I use to read dll files SDF2, and I need to get the feature class of objects. Similar to recover the key, url, etc ... :
SdfObject.Key, SdfObject.Url.
I would like to find the corresponding feature class.
Does anyone know answer me?
thank you
1 REPLY 1
Daniel.Du
Are you trying to export DWG to SDF? If yes, you can refer to this blog:
http://adndevblog.typepad.com/infrastructure/2012/03/exporting-dwg-to-sdf-using-epf-file-using-map-3...
This one may be helpful as well:
http://adndevblog.typepad.com/infrastructure/2012/03/how-to-use-command-line-version-of-mapexport-fo...
Daniel Du
Developer Technical Services
Autodesk Developer Network
