Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
SaveMWF in VBscript refuses to save
1 REPLY 1
devcrowley
1032 Views, 1 Reply
I'm trying to use the SaveMWF command in a VBA application.  I have a control called MapControl which is the MGmap ActiveX control.  It's able to load the maps up just fine, but it won't save to an MWF no matter what I try.  The error code returned is -5 (security violation) but I've tried saving it to numerous locations, including my temp files, without any success.
Here's the line I'm attempting to use to save the file:
MapControl.saveMWF("C:\\temp\\test.mwf", "")
I also tried:
Dim myMap As MGMap
Set myMap = MapControl
myMap.saveMWF("C:\\temp\\test.mwf", "")
msgbox myMap.getLastError.getCode    'Returns -5
Any ideas?  Thanks!
1 REPLY 1
gluckett
in reply to: devcrowley
Do you have a password on the MWF? You need to send it if you do.
