Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Runtime copy to SDF - slow
7 REPLIES 7
Message 1 of 8
o019909
842 Views, 7 Replies
Procedure in main page copies objects in SQL Server to SDF file
read in SQL - 10 seconds
write to SDF - 3 minute
read\write - 233781 objects
Why so slowly?
7 REPLIES 7
Message 2 of 8
o019909
in reply to: o019909
Copy in SQL Server to virtual (runtime) Features (SDF shema)
Read in SQL - 6 seconds
Write to Features - 1 minutes
Why so slowly?
Message 3 of 8
jackie.ng
The MapGuide Web API is not geared for bulk copy scenarios. If you want speed, you should go closer to the metal and build your process around FDO itself.
- Jackie
Message 4 of 8
o019909
in reply to: jackie.ng
hmmm
I present a copying code to the file....
but a copying code in a virutalny source..... hmmmmm
Message 5 of 8
o019909
hm...  I started FDO in my WEB APP!!!
if to write down every line - that very much and very slowly
_______________________________________________________________________________________
try
            IProviderRegistry mProvider = FeatureAccessManager.GetProviderRegistry();
IConnectionManager mManager = FeatureAccessManager.GetConnectionManager();
            IConnection mConnection = FeatureAccessManager.GetConnectionManager().CreateConnection(
"OSGeo.SDF.3.8");
            mConnection.ConnectionString =
@"File=C:\Program Files\OSGeo\MapGuide\Server\SDF_Data\ELEMENTmednogorsk.sdf";
            OSGeo.FDO.Connections.ConnectionState state = mConnection.Open();
            IInsert insertCmd = (IInsert)mConnection.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Insert);
            insertCmd.SetFeatureClassName(
"SHP_Schema:ELEMENT");
foreach(DataRow dr in tablo.Rows)
                insertCmd.PropertyValues.Add(
new PropertyValue("FeatId", new Int64Value((Int64)dr[0])));
                GeometryValue gm = (GeometryValue) dr[1];
new PropertyValue("Geometry", gm));
new PropertyValue("ID_CKZ", new Int32Value((Int32)dr[2])));
new PropertyValue("ID_obsl", new Int64Value((Int64)dr[3])));
Int64 mT = (Int64)dr[4];
new PropertyValue("ID_TYPE", new Int64Value(mT)));
new PropertyValue("Zapoln", new BooleanValue((Boolean)dr[5])));
if (mT == 1)
new PropertyValue("Preasure", new DoubleValue((Double) dr[6])));
using (IFeatureReader Freader = insertCmd.Execute())
                    Freader.Close();
                    col_insert_obj++;
            mConnection.Close();
            mConnection.Dispose();
            mManager.Dispose();
            mProvider.Dispose();
catch(System.Runtime.InteropServices.SEHException a)
            Response.Write(a.Message);
if to write down everything at once - a error
"OSGeo.SDF.3.8");
new PropertyValue("FeatId", new OSGeo.FDO.Expression.Parameter("PFeatId")));
new PropertyValue("Geometry", new OSGeo.FDO.Expression.Parameter("PGeometry")));
new PropertyValue("ID_CKZ", new OSGeo.FDO.Expression.Parameter("PID_CKZ")));
new PropertyValue("ID_obsl", new OSGeo.FDO.Expression.Parameter("PID_obsl")));
new PropertyValue("ID_TYPE", new OSGeo.FDO.Expression.Parameter("PID_TYPE")));
new PropertyValue("Zapoln", new OSGeo.FDO.Expression.Parameter("PZapoln")));
new PropertyValue("Preasure", new OSGeo.FDO.Expression.Parameter("PPreasure")));
String myConnectionString = sDataSource + ";" + Session["InitialCatalog"].ToString() + ";" + sPresistSecurityInfo + ";" + sUser + ";" + sPassword;
String filter_type = " (dbo.ELEMENT.ID_TYPE=1) or (dbo.ELEMENT.ID_TYPE=2) or (dbo.ELEMENT.ID_TYPE=3) or (dbo.ELEMENT.ID_TYPE=4) or  (dbo.ELEMENT.ID_TYPE=5) or (dbo.ELEMENT.ID_TYPE=6) or (dbo.ELEMENT.ID_TYPE=7) or (dbo.ELEMENT.ID_TYPE=8) or (dbo.ELEMENT.ID_TYPE=17) ";
//String mySelectQuery = "SELECT  FeatId, Geometry, ID_obsl, ID_TYPE, Zapoln, ID_CKZ FROM ELEMENT WHERE (" + filter_type + ") and (" + filter_obsl + ")";
String mySelectQuery = "SELECT   dbo.ELEMENT.FeatId, dbo.ELEMENT.Geometry, dbo.ELEMENT.ID_obsl, dbo.ELEMENT.ID_TYPE, dbo.ELEMENT.Zapoln, dbo.ELEMENT.ID_CKZ, "
"              dbo.GASLINE.Pressure "
"FROM         dbo.GASLINE RIGHT OUTER JOIN "
"              dbo.GASLINESOSTAV ON dbo.GASLINE.ID_Gazline = dbo.GASLINESOSTAV.ID_Gasline FULL OUTER JOIN "
"              dbo.ELEMENT ON dbo.GASLINESOSTAV.FeatID = dbo.ELEMENT.FeatId"
" WHERE (" + filter_type + ") and (" + filter_obsl + ")";
        SqlConnection myConnection =
new SqlConnection(myConnectionString);
        SqlCommand myCommand =
new SqlCommand(mySelectQuery, myConnection);
        myCommand.CommandType = System.Data.CommandType.Text;
        myCommand.Connection.Open();
        SqlDataReader myReader = myCommand.ExecuteReader(CommandBehavior.CloseConnection);
while (myReader.Read())
            col_read_obj++;
            ParameterValueCollection Pprops =
new ParameterValueCollection();
Int64 mF = myReader.GetInt64(0);
// add to FDOCOllection
            Pprops.Add(
new ParameterValue("PFeatId", new Int64Value(mF)));
            GeometryValue gm = (GeometryValue)Expression.Parse(
"GEOMFROMTEXT('" + myReader.GetValue(1) + "')");
            Pprops.Add(
new ParameterValue("PGeometry", gm));
//Response.Write(myReader.GetValue(1).ToString() + "<br>");
//Response.Write("<br> - " + agfReaderDB.Write(mGEOMDB).ToString() + " - <br>");
if (!myReader.IsDBNull(5))
                Pprops.Add(
new ParameterValue("PID_CKZ", new Int32Value(myReader.GetInt32(5))));
else
                Pprops.Add(
new ParameterValue("PID_CKZ", new Int32Value(0)));
            Pprops.Add(
new ParameterValue("PID_obsl", new Int64Value(myReader.GetInt64(2))));
Int64 mT = myReader.GetInt64(3);
            Pprops.Add(
new ParameterValue("PID_TYPE", new Int64Value(myReader.GetInt64(3))));
if (!myReader.IsDBNull(4))
                Pprops.Add(
new ParameterValue("PZapoln", new BooleanValue(myReader.GetBoolean(4))));
else
                Pprops.Add(
new ParameterValue("PZapoln", new BooleanValue(false)));
if (mT == 1)
if (!myReader.IsDBNull(6))
//props.Add(new MgInt64Property("Preasure", readPreasureGasline(mF)));
Double mP = (Double)myReader.GetDecimal(6);
                    Pprops.Add(
new ParameterValue("PPreasure", new DoubleValue(mP)));
else
                    Pprops.Add(
new ParameterValue("PPreasure", new DoubleValue(0)));
            insertCmd.BatchParameterValues.Add(Pprops);
        myReader.Close();
        StringEndDBDateTime =
DateTime.Now.ToString(" hh:mm:ss");
            Freader.Close();
            Freader.Dispose();
        insertCmd.Dispose();
ERROR:  Object reference not set to an instance of an object
Message 6 of 8
o019909
ERORR in line code:  insertCmd.BatchParameterValues.Add(Pprops);
Message 7 of 8
o019909
insertCms.BatchParameterValues returned NULL ................ FDO 3.8 not support batch insert to SDF !?!?!?!?!?
Message 8 of 8
o019909
hmmm....
in while cicle im post insertCmd.PropertyValue.Clear(); - copying its very very quickly
