Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Publish to MapGuide from Autodesk Architectural Desktop
0 REPLIES 0
Message 1 of 1
238 Views, 0 Replies
Anyone using Autodesk Architectural Desktop 2004
with the new Interoperability and Productivity Extension now has the ability to
publish the ADT model directly to MapGuide with just one command.  This
will create all the files that MapGuide uses as well as an Access database that
contains the non-graphical data that you need to see.  For more
information, check out
href="http://usa.autodesk.com/adsk/servlet/index?id=3640916&siteID=123112&linkID=2475907">http://us...
 where
you can see an AVI of this feature in action.
Cheers,
Julian
0 REPLIES 0
