Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Problem with use of dwgLoadprocedure
1 REPLY 1
brokosa
1373 Views, 1 Reply
i try to load a dwg file with program:
mgr = Autodesk.MapGuide.Studio.Site.SiteManager.GetInstance()
con = mgr.CreateConnection(<url>, <user>, <password>, stat)
loadProc = New Autodesk.MapGuide.Studio.Load.DwgLoadProcedure
loadProc.SourceFiles.Add(<file name>)
loadProc.RootPath = "Library://Test"
loadProc.GenerateLayers = True
loadProc.GenerateMaps = True
loadProc.GenerateSpatialDataSources = True
loadProc.GenerateSymbolLibraries = True
loadProc.LayersFolder = "layer"
loadProc.MapsFolder = "map"
loadProc.Execute(con)
but by execute an exception occured:
Fdo exception : Schema is not set - cannot set the class name.
How can I set Schema?
best regards
Boguslaw
1 REPLY 1
Daniel.Du
in reply to: brokosa
I would like to draw your attention that DWG is supported on AIMS 2013 without file format conversion or load procedure, so it is not necessary to do this any more. Please refer to this video: docs.autodesk.com/MAP/2013/ENU/map_videos_new_features/Publishing DWG files.html
and Infrastructure Studio help.
Please let us know if you are still blocked by this problem and want to keep working on it.
Daniel Du
Developer Technical Services
Autodesk Developer Network
