Do you mean mapserver? Which web layout are you using? If you are using basic layout you are in luck. If you are trying to use flexible layouts there is some kind of bug with the flexible layout stuff.
We modfied the quickplot.templ file to use different paper sizes.
John.
In the QuickPlotPanel.templ (C:\Program Files\Autodesk\Autodesk Infrastructure Web Server Extension 2014\www\fusion\widgets\QuickPlot\)
around line 105, add the following to get A0 plotting:
<option value="841.0,1184.0,A0">A0 (841x1184 mm ; 33.11x46.61 In)</option>
I added Gordon's Sheet size to QuickPlot and restarted Mapguide.
The Purple box looks good on the Screen however when I hit generate it creates a Blank Map inside the Map Area.
If I use Letter, Legal, Tabloid or 11x17 it works just fine but anything larger seeems to flake out.
Chris
Hi Chris;
Are you using basic layouts or flexible layouts ? And also what browser are you using; I had to switch our endusers over to Firefox instead of IE becasue of issues with quick plottng. Also something else with fusion or flexible layouts in mapserver 2014 ..using the quick plot and or plotting to PDF does not work for any other sizes Except for what they have listed in the .templ file. And another note which we found out; print margins will make your quick plot print more than one page also. So make sure that your page sizes in the .templ file are smaller than the actuall paper size they are set up for.
Hope that helps ..if you want I can post what our .templ file looks like also.
John
Hi Gordon,
We dont use any google or bing backdrops for our GIS. The scale thing would make sense but the preview generated has a picture not blank.
We have numourous support requests with Autodesk on this matter. What we get is a d-size print with just the other stuff on it. This and our other problem was at first we would get three pages for on print. So we finally figure out that the print margins and also the printable area was to big in the templ file. So we actually set the Length and width about 1 inch smaller so it didnt force the x,y, coords and the printing at the bottomo to another page.
So it seems like autodesk has a few bugs with the quick plot in general. If you can think of anything at all that would cause this blank page syndrome please let me know.
Thanks John
To modify the paper sizes for a basic layout in AIMS 2015 I had to edit C:\Program Files\Autodesk\Autodesk Infrastructure Web Server Extension 2015\www\viewerfiles\quickplotpanel.templ
