Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Preview error
5 REPLIES 5
269 Views, 5 Replies
Preview error
I am having this error in the Preview section in the MapGuide Studio
Resource was not found: Session:5cf98288-0000-1000-8002-000cf1808bcb_eng//Sheboygan_MapPreview.WebLayout
Resource was not found: Session:5cf98288-0000-1000-8002-000cf1808bcb_eng//Sheboygan_MapPreview.WebLayout Exception occurred in method MgResourceDefinitionManager.GetDocument at line 476 in file c:\build_tux_area\mgdev_opensource\server\src\services\resource\ResourceDefinitionManager.cpp "
from the server as it appears in the attachement below,i don't know where to find the path it have specified because my C drive does not have the folder built_tux_area.
Find the attachement
Does anyone knows what to do from here?
5 REPLIES 5
It looks like you have not loaded the Sheboygan.mgp sample dataset into your
repository.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
wrote in message news:5313718@discussion.autodesk.com...
476 in file
The documentation says the Sheboygan.mgp should be put in < C:\Program Files\MapGuideOpenSource\Server\Packages>
so that it can be uploaded in the Site Admin.Is it supposed to be in the repository again and which sub-folder because we have 4 of them.
Andy meant that you need to place the MGP into the packages directory,
and then use the site admin to load the data into the repository. You
should never need to access the repository directly... unless you are
updating your data through an external (non-Studio/Map) mechanism.
Jason
Although... from your screenshot it looks as if the sample has been loaded.
Does this error recur if you log out and then log back in? How about if
you save the layer, close it, and then reopen it? The fact that the
error message references a the session repository leads me to believe
that your session might have timed out. Although Studio appears to use
a longer timeout than the web client, I think that the preview function
uses the shorter web timeout interval.
Jason
Thanks a lot Jason and Andy,i managed to fix it,the preview does not give any error rite now.I did save the layer and reopen it again.I appreciate our help so much Guys.
