Infrastructure Map Server Developer
New Member
snrsarker
Message 1 of 4 (1,251 Views)
Plotting XY points on the map in AIMS
1251 Views, 3 Replies
08-09-2012 04:44 AM
I have coordinates of a point that I have readfrom a exel sheet provided by the user. I have written the following code in Java Script to digitize(plot that point in this case) that point on the map.
function ProcessCallBackResult(resulthtml)
      var points = resulthtml.split('||');
      var point1 = points[0].split('|');
     var x1=point1[0];
     var y1 = point1[1];
     var pnt=new Point(x1,y1);
     DigitizePointCustom(pnt);
   //  Refresh();
    function DigitizePointCustom(handler) {
        mgApiStartDigitizingCustom('point', handler)
    function mgApiStartDigitizingCustom(type, handler) {
        var mgApiMapWidgetIdCustom = 'Map';
        var mgApiActiveWidgetCustom = null;
        var mgApiActiveControlCustom = null;
        var mgApiDrawControlsCustom;
        var mgApiDigitizingLayerCustom = null;
        var mgApiInitializedCustom = false;
        mgApiInit();
        if (handler) {
            //var Fusion = window.top.Fusion;
            var mapWidgetCustom = Fusion.getWidgetById(mgApiMapWidgetIdCustom);
            var map = Fusion.getWidgetById(mgApiMapWidgetId).oMapOL;
            //mgApiActiveWidgetCustom = mapWidgetCustom.oActiveWidget;
            //var map = Fusion.getWidgetById(mgApiActiveWidgetCustom).oMapOL;
            var mgApiStyleCustom = new OpenLayers.Style({
            pointRadius: 4,
            graphicName: "square",
            fillColor: "blue",
            fillOpacity: 0.4,
            strokeWidth: 2,
            strokeOpacity: 1,
            strokeColor: "#666666"
        var mgApiStyleMapCustom = new OpenLayers.StyleMap(mgApiStyleCustom);
        Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED, mgApiInit);
         /*Digitizing tool initialization*/
         mgApiDigitizingLayerCustom = new OpenLayers.Layer.Vector("Digitizing Layer", {styleMap: mgApiStyleMapCustom});
         map.addLayers([mgApiDigitizingLayerCustom]);
         //mgApiDrawControlsCustom = { point: new OpenLayers.Control.DrawFeature(mgApiDigitizingLayerCustom, OpenLayers.Handler.Point, { handlerOptions: { layerOptions: { styleMap: mgApiStyleMapCustom}}})
            if (mgApiActiveWidgetCustom) {
                mapWidgetCustom.deactivateWidget(mgApiActiveWidgetCustom);
However the issue is the points are not getting plotted/visible on the map space. I am a new coder for autodesk. Please help.
Board Manager
Daniel.Du
Message 2 of 4 (1,239 Views)
Re: Plotting XY points on the map in AIMS
08-13-2012 01:11 AM in reply to: snrsarker
Actually you can add an ODBC feature source and layer from Infrastructure Studio without programming.
File -> new Data Connection, select "OSGeo FDO Provider for ODBC".
Daniel Du
Developer Technical Services
Autodesk Developer Network
New Member
snrsarker
Message 3 of 4 (1,235 Views)
08-13-2012 01:57 AM in reply to: snrsarker
Actually I have read an excel file where my x, y coordinates are given. I want to plot that point on the map in AIMS. My target is to allow the web user to plot the points on the map by simply uploading the coordinates through an excel sheet. Please help...
Board Manager
Daniel.Du
Message 4 of 4 (1,224 Views)
08-13-2012 10:58 PM in reply to: snrsarker
OK, in that case, you need to create a temp feature source and temp layer, then add the point features into this feature source using WebExtension API, I would suggest you to refer these code sample(Solution4/5/6) in http://download.autodesk.com/media/adn/AIMS_Sample_DevTV_Solution_5_6/MapGuideSamples2012.zip
Please also check the AIMS developer center page for more informtion including documents/DevTVs
http://usa.autodesk.com/adsk/servlet/index?id=946551&siteID=123112
Daniel Du
You are not logged in.
Ask the Community
