Infrastructure Map Server Developer
Valued Contributor
Message 1 of 1 (364 Views)
Pdf creation, BaseLayerGroup and Raster
364 Views, 0 Replies
04-24-2013 11:06 AM
I have a pdf creation function for AIMS2013 (Thank you Jackie for provide MgReadOnlyStream class) which used for create a pdf file based on which data layers clients turned on. If works fine except in one situation: a raster layer in the BaseLayerGroup.
The Map will shows hydro wells, roads, sevral other vector layers on the top of a Raster Image. Due to the whole map has more than 120 layers (all these layers will be on or off based on clients' need and also on/off based on certain scales), I have all the heavy data in the BaseLayerGroup, so the Raster layer has to be in the BaseLayerGroup, all the other data on the top of Raster Image. Then I found my pdf function cannot catch the raster image. If I put raster layer in the non-BaseLayerGroup, then there's no issue, see below image result
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
