Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
OGR FDO Provider for Personal Geodatabase
1 REPLY 1
423 Views, 1 Reply
Hi all,
I've just downloaded the trial version of MapGuide Enterprise 2010 and have run into a couple of problems. Firstly I wasn't sure how to connect to a personal geodatabase so, after scouring the web, I found a PDF showing this being done in an earlier version of MapGuide Enterprise using the FDO Provider for OGR. When i went to do the same the (new>Data connection>) I found i didn't have the option of the 'OSGeo FDO Provider for OGR'. After further searching I learned I had to download the .dll for this provider (making sure it was the same version as the other providers) and register it in the 'provider' xml document here: C:\Program Files\Autodesk\MapGuideEnterprise2010\Server\Bin\Fdo.
This i did, yet when I launch MapGuide Enterprise the 'FDO provider for OGR' is still not listed as a feature provider. Has anyone got any suggestions as to what I might be doing wrong or what i could try to resolve this? Or even whether or not there's an alternative way of connecting to geodatabase data.
Any help is obviously gratefully received.
Many Thanks
1 REPLY 1
dswilson
Did you restart your server after updating the providers.xml? You might also have to exit and restart Studio.
Dave
