I am looking for a way to theme values in the NAME column of a SDF file. The SDF file was built from multiple drawings - based on the layer name - using AutoCAD Map 3D 2007. Since the layer name is a different "case" in each drawing, MapGuide 6.5 recognizes layer "Test" and themes it as instructed, but not layer "TEST". Can I place a formula in the MapGuide Author to theme these layers as one? Can I place a formula in the MAP2SDF dialog box (in AutoCAD Map) that will enable this NAME column to be all UCASE\strcase?
