If I start developing using the Open Source MapGuide version and then later decided to use the Enterprise version can i use the exact same code and setup? (and vice versa)
As long as you are moving your code and data to a corresponding Enterprise version or newer version, there should be no problems.
- Jackie
Thanks jackie.
Does this apply both ways e.g. if some particular fix comes out in the open source version can I move from Enterprise to Open Source to take advantage of the fix?
It should be fine as long as your packaged data is not using the Autodesk commercial FDO providers (Raster/Oracle)
- Jackie
