Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Moving from Open Source to Enterprise
1 REPLY 1
517 Views, 1 Reply
If I start developing using the Open Source MapGuide version and then later decided to use the Enterprise version can i use the exact same code and setup?
1 REPLY 1
gluckett
Sure, just make sure you create the MGP file and you update your code to use the correct ini file.  It is actually easier moving from OpenSource to Enterprise than the other way around.
