I am interested in moving the Task Pane in my Fusion layout (maroon) to the bottom of the page. The type of data I am using in the task frame is better suited to a wider area. Is this possible and if so, where do i start?
Thanks!
There are a number of ways to solve this.
If you choose #2 you will find it a bit of work. You will have the modify the JX PANELS.
The splitter breaks the page into 2 "MapArea" and "Sidebar".
The sidebar has the 4 panels. Task Pane is "panel3"
These also refer to the DIV tags below.
check out http://jxlib.org/reference/api/files/Panel/panel-js.html to find out more about the panels.
