Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Mobile viewer Extension for Map Server Infrastructure
1 REPLY 1
swimming123
1417 Views, 1 Reply
When we use the Map Server Infrastructure, Does it matter to select Ajax viewer or Fusion Viewer?  Does Fusion will load normally on a mobile device? How can I make the Mobile viewer extension work? Thank you
1 REPLY 1
Daniel.Du
in reply to: swimming123
For mobile devices, it is recommended to use MobileViewer, which is much lighter than Fusion Viewer, please refer to this blog to check whether it helps or not: http://adndevblog.typepad.com/infrastructure/2012/06/creating-custom-control-for-mobile-viewer-of-ai...
Daniel Du
Developer Technical Services
Autodesk Developer Network
