When we use the Map Server Infrastructure, Does it matter to select Ajax viewer or Fusion Viewer? Does Fusion will load normally on a mobile device? How can I make the Mobile viewer extension work? Thank you
For mobile devices, it is recommended to use MobileViewer, which is much lighter than Fusion Viewer, please refer to this blog to check whether it helps or not: http://adndevblog.typepad.com/infrastructure/2012/06/creating-custom-control-for-mobile-viewer-of-ai...
