Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Mobile Viewer in 2014
0 REPLIES 0
Message 1 of 1
gluckett
432 Views, 0 Replies
just some notes for improvement and UI fixes for the Mobile Viewer:
  1. Correct the conflict between Layer or Properties and Map - when trying to scroll though more than 10 layers or 10 properties, the UI conflicts with the Map and the user cannot scroll down very well - it is a battle between the OpenLayers map and the Properties/Layer UI
  2. The sticky Legend.  After toggling the Legend, and then closing it, simply pan the map and the legend re-appears.  This little bug is pretty frustrating to the user.  Fixed by catching the deactivate event on the Legend close.
  3. Legend using the Pretty Name rather than acutal name of the layer.  For example, if Ihave a group called WINFRA but call it "Water Infrastructure" as the display name, I expect to see that in the legend, not WINFRA for example - this should be true for Columns, Layers and Layer Groups - no one wants to see the ugly names.
This list is just a quick note of what I have seen in 2014 Mobile Viewer so far.
0 REPLIES 0
