Infrastructure Map Server Developer
Valued Contributor
nik.mazreen
Message 1 of 10 (4,270 Views)
Mobile Viewer Extension for AIMS
4270 Views, 9 Replies
06-07-2011 09:05 PM
In this new release, aims 2012 already have mobile viewer extension. since i'm still in the learning process of this software, i would very appreciate if anyone could give me any guideline on how to make used of this mobile extension so that i can try to apply my sample map into either ipad or iphone..or atleast any website that i can go to for me to find out more about this extension.
Thx..
Nik
ADN Support Specialist
Message 2 of 10 (4,186 Views)
Re: Mobile Viewer Extension for AIMS
07-03-2011 07:10 PM in reply to: nik.mazreen
Firstly you need to install the component seperately, from <AIMS2012 CD_ROM>\TechnologyPreview
After installation you can find the viewer at C:\Program Files\Autodesk\Autodesk Infrastructure Web Server Extension 2012\www\MobileViewer
And a document at C:\Program Files\Autodesk\Autodesk Infrastructure Web Server Extension 2012\www\MobileViewer\docs\MobileViewer.docx
To use the mobile viewer :
http://localhost/mapserver2012/MobileViewer/index.html
You may need to modify the source code of index.html at  C:\Program Files\Autodesk\Autodesk Infrastructure Web Server Extension 2012\www\MobileViewer
Here are some domo applications online:
http://sandbox.mapguide.com/iviewer/
Daniel Du
Developer Technical Services
Autodesk Developer Network
Member
Message 3 of 10 (4,095 Views)
07-26-2011 10:14 PM in reply to: Daniel.Du
I downloaded AIMS from the subscription centre, and don't have the DVD media.  It appears the download does not include the technology preview for the mobile viewer extension.
How can I get access to this?
Valued Contributor
nik.mazreen
Message 4 of 10 (4,089 Views)
07-27-2011 12:50 AM in reply to: david.roy
Hi again,
it has been quite a while. now, i already install mobile viewer. since i dont have any programming background, how can i use this mobile viewer?i already create a map using infrastructure studio, how do i want to publish this map using mobile viewer?
thx in advance.
-Nik-
Valued Mentor
Message 5 of 10 (4,083 Views)
07-27-2011 07:00 PM in reply to: david.roy
The installer should be under the TechnologyPreview directory of the installation media.
- Jackie
Member
ralfzenklusen
Message 6 of 10 (3,852 Views)
10-11-2011 08:02 AM in reply to: nik.mazreen
Hi Nik
You have to change the index.html file (C:\Program Files\Autodesk\Autodesk Infrastructure Web Server Extension 2012\www\MobileViewer). It is in my opinion not possible to view and edit the mobile site like a template in MapGuideStudio.
To make the first steps: I copied the index.html (located at C:\Program Files\Autodesk\Autodesk Infrastructure Web Server Extension 2012\www\MobileViewer) file and changed the variable defaultMapDef (line 43) to an existing map definition. Now the viewer works. You can access the viewer with this adress: http://hostname/mapserver2012/MobileViewer/index2.html.
For debugging it's better to use the links to non compressed files (described in the index.html).
Best
Message 7 of 10 (3,660 Views)
11-18-2011 04:54 AM in reply to: ralfzenklusen
Hi I have tested the demos at the link http://sandbox.mapguide.com/iviewer/ but don't work.
Where I can find docs about mobile viewer?
Matteo
Message 8 of 10 (3,610 Views)
11-23-2011 12:07 AM in reply to: matteo.conte
A MobileViewer.docx can be found in mobile viewer installation folder\docs.
Daniel Du
Active Contributor
tmblackflag
Message 9 of 10 (3,504 Views)
12-14-2011 12:32 PM in reply to: Daniel.Du
when i load my viewer i get a firebug error saying \MobileViewer\localized\en.json is 404 file not found. I've looked that directory over and the file is definitely there.
this leads to a "failed to load localized strings error" and the app hangs.
wilsonherrera
Message 10 of 10 (2,251 Views)
10-19-2012 08:52 AM in reply to: nik.mazreen
i know this is a bump of an older thread, but i am experiencig this same problem.
is there a way to solve thi sissue?
best regards,
Wilson H
You are not logged in.
Ask the Community
