Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
MgSiteConnection error
0 REPLIES 0
Message 1 of 1
santosh.venkatesh
461 Views, 0 Replies
 I am currently upgrading my project from Autodesk MapGuide 2011 to AIMS 2014(C#,ASP.NET Project, SQL Server 2008R2)
I have changed the server site URL
from http://localhost/mapguide2011/mapviewerajax/?SESSION=<%=Session["sid"]%>&WEBLAYOUT=<%=Session["layou...
to "http://localhost/mapserver2014/mapviewerajax/?SESSION=<%=Session["sid"]%>&WEBLAYOUT=<%=Session["lay...
and web.config from path
from <add key="WebConfigPath" value="c:\\Program Files\\Autodesk\\MapGuideEnterprise2011\\WebServerExtensions\www\\webconfig.ini" />
to <add key="WebConfigPath" value="c:\\Program Files\\Autodesk\\Autodesk Infrastructure Web Server Extension 2014\\www\\webconfig.ini" />
When I run the application the map loads fine the first time but when I perform a select/get selected feature operation then I run the code
        String mgSessionId = Session["Session"].ToString();
        String mgMapName = "map";
        String configPath = ConfigurationManager.AppSettings["WebConfigPath"];
        MapGuideApi.MgInitializeWebTier(configPath);
        MgUserInformation userInfo = new MgUserInformation(mgSessionId);
        MgSiteConnection siteConnection = new MgSiteConnection();
        siteConnection.Open(userInfo);
 the siteConnection.Open(userInfo) throws an error "Session has expired or is invalid. Please log in again"
 Therefore I am unable to get the selected object from the map, Please suggest/guide me as to how I can hadle this
Regards
Santosh V
0 REPLIES 0
