Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Measuring tool in AIMS2013 NOT stop by double click.
4 REPLIES 4
swimming123
974 Views, 4 Replies
I found measing tool does't stop by double click. It is annoying bug.
4 REPLIES 4
in reply to: swimming123
Double click works. I'm guessing it just has a very low tolerance making most double clicks not register
- Jackie
swimming123
It works on FireFox, not IE for me. I don't know how to fix this if it's because of tolerance. Thank you Jackie.
Questions:
1) Which version of IE do you use?
2) If IE 9: Are you running IE in Compatibility mode?
3) What is the language of your operating system (OS)?
Things I've noticed:
- Double click works fine in IE 9 (without Compatibility mode), Firefox, Chrome and Safari.
- It doesn't work on IE 7 and IE 8.
- In IE 9 it doesn't work if you have enabled the Compatibility mode.
Also I've noticed that some functions doesn't work proper on a non-English OS.
However (as a workaround) 'SHIFT + left mouse click' works with all browsers (even IE 6).
System: MapGuide Open Source 2.4 as well as AIMS 2013 with Apache on Windows Server 2012 (German OS)
- Bernhard
Yes, it works without compatibility mode. Thank you for the information.
