Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Markup example for Mapserver 2012
4 REPLIES 4
845 Views, 4 Replies
Good Day All!!! Has anyone tried to use the sharable markup example (I believe it was call gt.zip) that came out a few years ago with Mapserver 2012/2013?? I had downloaded this for use with Mapguide Enterprise 2009 and it worked great for what I was doing, but doesn't seem to work with Mapserver2012. I don't get any error messages, and I'm sure with the change to Mapserver there was some coding changes, but I was hoping someone has had success getting it to work, or using something similar for sharable markups. Thanks!!
4 REPLIES 4
gluckett
Don't forget to make an authoring user in the administrator.
Markup - markup
for username and password
make sure your layout logs in with this user when you open the layout
in reply to: gluckett
That was certainly part of my problem...I'm close to having this...but I'm getting an error listed below out of the Mapserver log files:
<2012-10-29T09:36:02>  4832 Ajax Viewer 140.139.196.103 Administrator
 Error: Failed to stylize layer: _howard33333
        The coordinate system initialization failed.
        Could not initialize the geodetic transformation.
I'm creating shp files and dwf files using Autodesk Map. I believe it doesn't like the coordinate system, but I've tried different ones to no avail.
gluckett
Yes, the definition of LL84 has changed (this is true for MGOS 2.4 too)
I had this issue before, find how I fixed it here:
http://osgeo-org.1560.n6.nabble.com/API-Change-in-MG-2-4-tt4996684.html#a4997139
That did work for me!!! Thanks alot!!!!! One last question...this only works for data with a true coordinate system doesn't it?? I have some data that I published, but becasue it wasn't in a true coordinate system, I used the arbitrary XY-FT when I published my data, and the markup tool doesn't seem to work on that...but I have other data, with true coordinate systems, and it appears to work on that just fine.
