Infrastructure Map Server General Discussion
Member
DEVR1930
Message 1 of 5 (484 Views)
Maptip to change into image gallery
484 Views, 4 Replies
04-05-2012 12:57 AM
I am trying to create a Image gallery inside the map. when i click on the MapTip Layers, an image gallery window should popup. Is it possible to activate a hyperlink from Maptip. Please suggest me some ideas. Thank you.
sroussev
Message 2 of 5 (469 Views)
Re: Maptip to change into image gallery
04-05-2012 09:40 PM in reply to: DEVR1930
Hey,
I think you can find useful info here:
http://themapguyde.blogspot.com/search?q=tooltips
Valued Contributor
pg002a
Message 3 of 5 (455 Views)
04-09-2012 11:32 AM in reply to: DEVR1930
Member
DEVR1930
Message 4 of 5 (448 Views)
04-09-2012 06:00 PM in reply to: sroussev
thank u all :smileyhappy:
Member
DEVR1930
Message 5 of 5 (429 Views)
04-12-2012 12:17 AM in reply to: DEVR1930
Is it possible to implement Auto Re-Size Maptip i.e. When the user resizes the map browser window the embedded viewer will also resize and the background of the Viewer should be translucent.And Maptip viewer should cover about 90% of the display map area. i try to edit maptip.js file inside fusion/widget folder. But then i dint get any result when i change the folder.
can a Maptip gallery be implemented by these requirement?
You are not logged in.
Announcements
Need installation help?
Ask the Community
