Infrastructure Map Server General
Active Member
Message 1 of 4 (860 Views)
Accepted Solution
Mapguide Enterprise 2011 on Windows Server 2003 SP2
860 Views, 3 Replies
03-09-2011 07:34 PM
I don't see the list of FDOs needed to establish a data connectiown when I use Mapguide Studio 2011 to connect to MGE 2011 installed on windows server 2003 sp2. I uninstalled and reinstalled .Net 2.0 2.0 SP1, 3.0, 3.5 and 4.0 but no cigar
The list does appear if I connect to MGE 2011 installed on windows server 2008 R2..
I have had MGE 2009 running on Windows Server 2003 without a problem but now I need to migrate to 2011 without the need for w2k8.
Is there a fix around it?
Active Member
Message 2 of 4 (806 Views)
Re: Mapguide Enterprise 2011 on Windows Server 2003 SP2
03-18-2011 02:15 PM in reply to: mauricio.villablanca
53 views (which means a lot of people have the same problem) but no replies. Gee thank you Autodesk.
I'm looking forward to purchasing MGE 2012. <roll eyes>
Active Member
Message 3 of 4 (787 Views)
03-20-2011 09:55 PM in reply to: mauricio.villablanca
I managed to find a fix that barely suits my needs. Autodesk screwed up really bad on this one by including some FDO provider binaries not compiled for windows server 2003.
I edited the providers.xml and kept the Oracle, the MS SQL and Raster providers only, restarted the Mapguide server and it worked.  I can now now see at least the three providers that my company mostly uses. The SHP provider is broken (others might be too, I didn't test them). If you attempt to load SHP files, Mapguide Studio will give you the error message "The OSGeo.SDF provider provider is not supported".
I tried to use the SHP FDO provider from MGE2009 but it didn't work either.
Shame on you Autodesk. Shame on you.
Active Member
Message 4 of 4 (778 Views)
03-20-2011 11:20 PM in reply to: mauricio.villablanca
Final update:
I finally got Mapguide Studio to show all the providers I need by modifying the providers.xml file and setting the providers in the following order:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<FeatureProviderRegistry>
    <FeatureProvider>
    <Name>OSGeo.SDF.3.5</Name>
    <DisplayName>OSGeo FDO Provider for SDF</DisplayName>
    <Description>Read/write access to Autodesk's spatial database format, a file-based personal geodatabase that supports multiple features/attributes, spatial indexing, and file-locking.</Description>
    <IsManaged>False</IsManaged>
    <Version>3.5.0.0</Version>
    <FeatureDataObjectsVersion>3.5.0.0</FeatureDataObjectsVersion>
    <LibraryPath>SDFProvider.dll</LibraryPath>
  </FeatureProvider>
  <FeatureProvider>
    <Name>OSGeo.SHP.3.5</Name>
    <DisplayName>OSGeo FDO Provider for SHP</DisplayName>
    <Description>Read/write access to spatial and attribute data in an ESRI SHP file.</Description>
    <LibraryPath>ShpProvider.dll</LibraryPath>
  </FeatureProvider>
  <FeatureProvider>
    <Name>Autodesk.Raster.3.5</Name>
    <DisplayName>Autodesk FDO Provider for Raster</DisplayName>
    <Description>Read access to various raster-based file formats. Supports georeferenced file-based raster images, DEM files and 3D grid surfaces.</Description>
    <LibraryPath>FDORFP.dll</LibraryPath>
  </FeatureProvider>
  <FeatureProvider>
    <Name>Autodesk.Oracle.3.5</Name>
    <DisplayName>Autodesk FDO Provider for Oracle</DisplayName>
    <Description>Read/write access to feature data in an Oracle-based data store. Supports spatial indexing, long transactions, and persistent locking.</Description>
    <LibraryPath>FdoRdbms.dll</LibraryPath>
  </FeatureProvider>
  <FeatureProvider>
    <Name>Autodesk.SqlServer.3.5</Name>
    <DisplayName>Autodesk FDO Provider for SQL Server</DisplayName>
    <Description>Read/write access to feature data in a MS SQL Server-based data store. Supports geospatial and nongeospatial data and schema R/W access.</Description>
    <LibraryPath>SqlServerProvider.dll</LibraryPath>
  </FeatureProvider>
  <FeatureProvider>
    <Name>OSGeo.SQLServerSpatial.3.5</Name>
    <DisplayName>OSGeo FDO Provider for SQL Server Spatial</DisplayName>
    <Description>Read/write access to feature data in a MS SQL Server Spatial data store. Supports geospatial and nongeospatial data and schema R/W access.</Description>
    <LibraryPath>SQLServerSpatialProvider.dll</LibraryPath>
  </FeatureProvider>
</FeatureProviderRegistry>
Restarted MGE2011. Now the list is displayed correctly in Mapguide Studio.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
