I am trying to use visual studio to developer an application with mapguide 2012. I want to use visual studio in a different machine where is mapguide server 2012. Using mapguide 2011, I shared the www folder, and edited the webconfig.ini file to point to this folder. It worked fine, but when I upgraded to mapguide 2012, I edited the webconfig.ini to this folder, but it is not working. I receive a message The server xxxx in Autodesk Infrastructure Map requests an user and password. There is some authentication issue between the two machines in this version ?
