Does anybody have any info. on this? This is happening to me MapGuide
Server5 (with applied SP fr. autodesk) on Win2K. Memory is leaking from
dllhost.exe and mapserver.exe runs at 99% CPU a few times a day, which
causes layer access to timeout. Checked the code and it seems fine (no
infinite loops, recordsets, connections closed, etc...) So far memory leak
on dllhost running MG Server 6 does not do this with the same code
(different machine, Win2K). though there are other problems with MG6
preventing me from switching now...Any thoughts?
"Manoj Desai"
wrote in message
news:AAC597303D20A5C6447652DE990FA076@in.WebX.maYIadrTaRb...
> I'm not sure how this article helps. I am experiencing this same problem
> with nt4.0 and sp6 with mapguide 6 and I just patched with the patch that
> came out on the 17th. Is that all I can do?
> "Pierre Cardinal" wrote in message
> news:A6154E625A56C59882389BF3763C9B04@in.WebX.maYIadrTaRb...
> > Hi,
> > Excerpt from MG603ServicePackReadme.htm
> > Autodesk MapGuide 6.0.3 - Service Pack Readme
> > In an effort to continuously improve the quality and stability of our
> > products, Autodesk® is releasing this Service Pack. We believe that this
> > update will improve our customers' experience with Autodesk MapGuide®.
> > This Service Pack includes the following software updates:
> > Autodesk MapGuide Server (Release 6.0.3.2)
> > Autodesk MapGuide Provider for Oracle Spatial (Release 6.0.3.2)
> > Autodesk MapGuide Author (Release 6.0.3.3)
> > Autodesk MapGuide Viewer ActiveX Control (Release 6.0.3.3)
> > Autodesk MapGuide Viewer Plug-In (Release 6.0.3.3)
> > This Service Pack addresses the following issues:
> > Autodesk MapGuide Server Failing as Memory Usage Climbs
> > The problem of Autodesk MapGuide Server crashing as memory usage climbs
> has
> > been fixed.
> > Autodesk ©
> > Pierre Cardinal
> > "Scott D. Daniel" a écrit dans le message
> news:
> > 8B1B7530250F5D2137504F77C195CDAC@in.WebX.maYIadrTaRb...
> > > Has anyone had problems with the MapServer.exe chewing up memory or
not
> > > releasing resources? Intalled on NT4 with sp6a. I'm finding it
necessary
> > to
> > > reboot the server nearly every week because MapServer.exe is growing
in
> > it's
> > > need for memory resources. Is there a fix? Is this an issue with
Windows
> > > 2000 server?
> > > Scott D. Daniel
> > > GIS Supervisor
> > > Ruekert · Mielke
> > > W233 N2080 Ridgeview Parkway
> > > Waukesha, WI 53188
> > > (262) 542-5733
> > > (262) 542-5631 Fax
> > > sdaniel@ruekert-mielke.com
