I'm following the Exercises in the Getting started guide. However the layer Preview panel never disaplays any maps etc...
When I click on Refresh nothing is displayed(except the Refresh button and the map tooolbar) - the map area is a greyed out box there are no errors or any such data displayed that I can use to diagnose the problem either.
Any suggestions?
I normally house the layer I want to preview in a temporary Map Definition and preview that instead.
Are you using the Fusion or AJAX viewer for previewing? I find the Fusion viewer produces more reliable results when previewing layers.
- Jackie
I solve it. You have to turn off the IE enhanced security configuration in your server!
That's the problem, works fine!
get to Server Manager for it
