Hello!
I have a problem with autostarting of MapGuide Plug-In from a web-site.
If I start the site it is always telling me that the Autodesk ActiveX component is not installed, although I installed it many times.
So now I already invested hours to check the IE settings (pop-ups, ActiveX execution, scripting, etc.) and enabled also on Windows level the exeution of ActiveX programs (linked to the Autodesk dll MgAxCtrl.dll).
Still it doesn't work.
Now I checked the installed Add-Ons of IE and Autodesk is not shown up there (???).
Even if it is installed at the moment.
You can test it with this web-page which is not working for me:
www.katasterportal.sk - then click on the left side on "Zobrazenie mapy"
then the map of Slovakia should open but it doesn't 😞
I really would appreciate your support since I am no really out of ideas as it already worked once but after restart it didn't again...
System configuration:
Windows 7 x64
Internet Explorer 9 x64
Autodesk MapGuide Viewer 6.5 SP1 ActiveX
Thanks a lot in advance
Thomas
