Infrastructure Map Server General Discussion
Active Member
Heidi03
Message 1 of 2 (542 Views)
MapGuide 2012 - Issue With Filters on Layers
542 Views, 1 Replies
02-10-2012 10:02 AM
Hello All,
I am in the process of upgrading from MapGuide Studio 2010 to 2012 and I am wondering if anyone else if running into any issues when applying filters to their map layers?
I'm using an Oracle connection to get my data, which works, and all my data shows up that's in the database.  However when I want to filter out and show only the "BID" data, the result is nothing being displayed.  Yes, there is "BID" data in the database.  It seems to be happening to all my tables in Oracle, not just this one.
However, all the sdf and shp datasets I can use the filter application with perfectly, just not Oracle.  P.S. Ths worked in MapGuide 2010, no problem...
Please Help,
Heidi
Valued Mentor
jackie.ng
Message 2 of 2 (533 Views)
Re: MapGuide 2012 - Issue With Filters on Layers
02-12-2012 05:36 PM in reply to: Heidi03
You should preview the Oracle Feature Source to ensure that not only the table(s) and column(s) you are filtering on are there, but also that they are in the same case (If I recall, filters are case-sensitive)
- Jackie
You are not logged in.
Ask the Community
