Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
ManagedMC3 Error
1 REPLY 1
AliKara1
1127 Views, 1 Reply
ManagedMC3 Error
Hi everyone;
I want to make a simple application about MapGuide
 string webLayout = "Library://SheBoyganPublic/WebLayouts/Test.WebLayout";
        string defaultUser = "Anonymous";
        string defaultPassword = "";
        string sessionId = "";
        protected void Page_Load(object sender, EventArgs e)
            try
                MgUserInformation userInfo = new MgUserInformation(defaultUser, defaultPassword);
                MgSite site = new MgSite();
                site.Open(userInfo);
                sessionId = site.CreateSession();
            catch (Exception ex)
                Response.Write(ex.Message);
I copied sample code from Setup Folder, Then I add all OsGeo dll's then published under IIS
when I open published page I get error like following text
My IDE Visual Studio 2010 Supports x64, AutoDesk Infrasracture Map 64 bit and IIS application pool supports 64 bit application I set to false 32 bit application compatibility from IIS, my IIs versiyon 7
How do I run this code, My AutoDesk Infrasracture Server is Trial
ERROR TEXT :
'ManagedMC3' file, or the compilation or one of its dependencies. Strong name signature could not be verified. The file, or the file can be played on the delay signed but not the correct private key can be fully signed. (Exception from HRESULT is returned: 0x80131045)
1 REPLY 1
AliKara1
in reply to: AliKara1
I fixed  this error with adding InitializeWebTier method before codes
thanks
