Hi everyone;
I want to make a simple application about MapGuide
string webLayout = "Library://SheBoyganPublic/WebLayouts/Test.WebLayout"; string defaultUser = "Anonymous"; string defaultPassword = ""; string sessionId = ""; protected void Page_Load(object sender, EventArgs e) { try { MgUserInformation userInfo = new MgUserInformation(defaultUser, defaultPassword); MgSite site = new MgSite(); site.Open(userInfo); sessionId = site.CreateSession(); } catch (Exception ex) { Response.Write(ex.Message); } }
I copied sample code from Setup Folder, Then I add all OsGeo dll's then published under IIS
when I open published page I get error like following text
My IDE Visual Studio 2010 Supports x64, AutoDesk Infrasracture Map 64 bit and IIS application pool supports 64 bit application I set to false 32 bit application compatibility from IIS, my IIs versiyon 7
How do I run this code, My AutoDesk Infrasracture Server is Trial
ERROR TEXT :
'ManagedMC3' file, or the compilation or one of its dependencies. Strong name signature could not be verified. The file, or the file can be played on the delay signed but not the correct private key can be fully signed. (Exception from HRESULT is returned: 0x80131045)
