Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
265 Views, 5 Replies
MYSQL
I am using MYSQL with MYODBC. If I create point layers with X Y Coordinates
and connect to the MYSQL Database it works fine. However if I am using SHP
files for the Layer Geom and try and link to a secondary table I get and
error stating: "ODBC Driver does not support the requested properties"
Does anyone else use MYSQL and has anyone ever run into this error?
Mike DelloIacono
5 REPLIES 5
Uzytkownik "Mike DelloIacono" napisal w wiadomosci
news:216179279DB9D12892F816738A8E7BF3@in.WebX.maYIadrTaRb...
Coordinates
> Thanks,
> Mike DelloIacono
we have the same problem with MySQL database.
As secondary table for any SDF layer is unaccesible.
Probably it's some bug in MySQL ODBC provider.
See post from gombi, 13MAR2003 at autodesk.mapguide.developer
Best regards
Jacek Przepiorkiewicz
MODGiK/SIT
www.modgik.lodz.pl/mapa/lsip.htm
samoy
Hi
Download the MySQL OLEDB Provider to eliminate this problem.
regards
Sam Majid
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hi
regards
Sam Majid
Hi Sam,
download from?
Jack
samoy
Jack
Try this link
http://www.mysql.com/downloads/download.php?file=Downloads/Win32/MyOLEDB.exe&pick=mirror
cheers
Sam
HI.
I have tried
both the ODBC and the OLEDB for MySQL and it fails.
ODBC ver 2.40.37 and ver 3.51.06 fails in Mapguide
6.0 and 6.3 (message: "557... cannot enumerate tables...")
MyOLEDB ver 3 fails in Mapguide 6.0 and 6.3 (gives
no message, just hangs so I have to reboot...)
I have read somewhere that the tables had to be
indexed, so I did, with no result...
Does anyone use MySQL with MapGuide?
Kjell-Olav
Hi
regards
Sam Majid
Hi Sam,
download from?
size=2>Jack
