I installed MGE Server 2009 to Linux (CENTOS 4.5) and done the configuration succesfully.
I followed the testing procedure stated in the ReadMe pdf files.
However;
When I try to connect MG Studio 2009 to the installed server, there is an error message. MG Studio is installed in an Windows XP Pro SP2.
What might be the cause and the solution for this?
When doing the configuration testing in the Linux Server itself, it works!
(i.e. http://localhost:8008; http://localhost:8008/mapguide2009/index.html; http://localhost:8008/mapguide2009/mapagent/mapagent.fcgi?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&RESOURCEID=Library://; http://localhost:8008/mapguide2009/mapagent/index.html; http://localhost:8008/mapguide2009/phpinfo.php; http://localhost:8008/mapguide2009/mapadmin/login.php using
UserID: Administrator
Password: admin
However, when I am trying to access the server from my WinXPPro workstation, using IE, replacing localhost by the server's IP address, it returned
ERROR
The requested URL could not be retreived etc, etc...
The Server's IP address is automatically obtained not a static set IP, does this affect?
I suppose that when i do the said configuration testing, it will work. How am I able to make this work?"
