Why not use WMS? You can publish you data in MapGuide in WMS and consume it with Map 3D with all the styles retained.
Hi I totally understand your frustration. The FDO to DWG chasm is still only bridged with a lot of manual labour (exporting DWG into FDO ready types such as SDF or Oracle) or through FME from Safe Software.
I would like to see a FDO Provider for DWG with read/write - that would be nice to use DWG with Autodesk Geospatial Products like MapGuide -currently you have to Load Procedure into SDF or export as a DWF manually.
...and your stylization to be easily created with the interface rather than loading with XML...
In the meantime, WMS will retain your stylization (but only read-only).
Sorry, didn't know it was showing. Been trying to solve this problem since MG 6.5 went off the screen. Getting no response from Adesk.
A trick I use it to make a two layer folder on the map using a dwf of the dwg and an "invisible" sdf with attribute data on top so the user can select items. Bulks it up but works somewhat.
Hi Dave.
Can you help me, about mapguide...
I have a map, that a want to print using a plotter. It's possible??
I did try, but only it printed the browser's frame, and I need to see my map on a paper of 3,0 mt x 1,70 mt.
Thanks.
mel.
I'm not sure you will get the resolution you desire, but you can add a command to your layout to plot to DWF. You can then print the DWF on the plotter.
A more complex solution that might improve what you want you get is to use the sample application for Sheboygan which includes a set of plot options that might better provide what you need, but you would have to replace the map in the sample app layout with your own to use it out of the box. I haven't tried modifying a layout to link to the page that the sample applications call, but that might be an option too.
Hopefully you can get something reasonable without any programming. There is API that may expose more options than shown in the sample applications, but that is likely too complex.
Dave
Thank you so much, Dave..
I did try the first option: DFW and your print control (choosing a plotter).
Everything it's ok.
Mel.
