Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Java Viewer Setup
1 REPLY 1
jacklloyd
212 Views, 1 Reply
Java Viewer Setup
I have some MG clients using Sun workstations with Netscape 7.1. They can access my development server (MG 6.3) with the Java Viewer and see the layers in an MWF. When they try and access the same MWF on my production server (MG 6.3), they get the MWF okay, but all of the layers have red Xs by them. I can use IE and the AX Control to access either MWF with no problems at all. Is there something that must be done on the server to allow access using the Java Viewer? The whole Java Viewer installation thing is very confusing. Is there any DETAILED documentation about setting it up, what components are needed and where they should located?
Thanks, Jack Lloyd
1 REPLY 1
jacklloyd
in reply to: jacklloyd
Never mind, I figured it out.
Jack
