Am using mapguide to publish a featuresource sql server spatial, if i connect with 'sa' or owner i have no problem, but when i connect with a restricted user to select only graphic tables i get this error:
Error occurred in Feature Source (Library://XXXXX/Data/SqlServerSpatial.FeatureSource): RDBMS: [Microsoft][SQL Server Native Client 10.0][SQL Server]The SELECT permission was denied on the object 'sql_expression_dependencies', database 'mssqlsystemresource', schema 'sys'. (Cause: RDBMS: [Microsoft][SQL Server Native Client 10.0][SQL Server]The SELECT permission was denied on the object 'sql_expression_dependencies', database 'mssqlsystemresource', schema 'sys'. , Root Cause: RDBMS: [Microsoft][SQL Server Native Client 10.0][SQL Server]The SELECT permission was denied on the object 'sql_expression_dependencies', database 'mssqlsystemresource', schema 'sys'. )
I am using Flex viewer.
I think it is a permisson issue, but, what are the minimum permissions required for a user?...
This issue still exists with Autodesk Infrastructure Map Server 2016.
I think it was re-introduced again after being fixed at one time.
