I have an iframe in a Maptip which works fine in the Desktop platforms in all browsers. When I tried opening it in the Mobile devices like iPad or any other android tablets, the Maptip seems to be not working. I think the reason for this is there is no mouseover option in the Tablets or iPad. I believe that if a click event is fired rather than a mouseover event, it should work just fine.
Any thoughts will be helpful and much appreciated.
Cheers
Dom
You are correct that there is no mouseover event for tablets because tablets have no mice, so such an event could never be raised.
Instead of mousemove, perhaps you could try triggering the map tip from the MAP_SELECTION_ON event raised by the map widget.
- Jackie
Thanks Jackie. I am not really sure about to make a call to trigger map tip from the MAP_SELECTION_ON event. I went through the JS files. But as I am not an expert with this, I could not really understand the code. Could you please explain it a bit more.
Many Thanks
Dom
