Hi Mark,
Thanks for responding. I was just about to add a follow-up message to say
that the problem has been solved. It was not related to Mapguide at all:
something must have happened during the file transfer because someone ftped
the file again and it works fine.
I found the performance of Mr. Sid's images quite disapointing though. We
have fairly large ecw images (1.4GB) and they are much faster. Perhaps we
are expecting too much; this Mr. Sid image is a 1.7GB file served over the
web after all.
Thanks again for your response.
Suzanne
"Mark Christian" wrote in message
news:69BECD0917F81E74CBD540DBDAFF6A66@in.WebX.maYIadrTaRb...
> Hello Suzanne,
> Does the image display in Autodesk Map, Raster Design, or any other
> product besides MapGuide?
> This is probably not an issue seeing that the error is also happening in
> Raster Workshop, but you could try increasing the MapGudie Server timeout
> parameter. See solution TS66773 http://usa.autodesk.com/getdoc/id=TS66773
> And finally can you tell me what version of Autodesk MapGuide you are
using
> and the version of the Mr.SID file (MG2, MG3, etc.)?
> Regards,
> Mark Christian
> Autodesk Professional Services - Infrastructure Solutions
> http://www.autodesk.com/professionalservices
> "Suzanne" wrote in message
> news:96EEB40B94D1BE8012CF6660B201AA28@in.WebX.maYIadrTaRb...
> > Hi,
> > I have a large Mr. Sid image (1.7 GB) and I get the following error when
> > trying to display it in Mapguide Author:
> > "Autodesk Mapguide Server error: 500-12174"
> > "The server encountered an internal server error. Please contact your
> system
> > administrator"
> > If I try to open it with the Raster Workshop, it crashes.
> > The image can be viewed with Arcview without any problems.
> > Any ideas?
> > Suzanne
