Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Infrastructure Map Server 2013 on Windows Server R2 Standard
7 REPLIES 7
Message 1 of 8
2511 Views, 7 Replies
The system requirement for the above product as shown in the document
System Requirements (64-bit)
Operating System
• Server components: Windows Server® 2008 Enterprise, Service Pack 2 (SP2)
Question: is there a difference if the product is installed in Windows Server 2008 R2 Standard?
7 REPLIES 7
Message 2 of 8
Daniel.Du
Windows Server® 2008 Enterprise is the officially supported OS, but I expect it runs on Windows Server 2008 Standard as well, although is it not officially supported.
Daniel Du
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
ahgaitana
Hi Daniel,
Is Infrastructure Map Server2013 will still work for Windows Server 2003 R2 standard?
We also use IIS6 as our services? will still run?
Buddy
Tags (2)
Message 4 of 8
Daniel.Du
in reply to: ahgaitana
Hi Buddy,
AIMS 2013 is only tested on the OS which is described in the system requirement document, it may run on other OS, but please note that it is not officially supported.
I personally did not try Windows Server 2003 with IIS6, so I have no say about it, I tried on Windows7, it works, of cause it is not suitable for production environment.
Hope this clarifies.
Daniel Du
Message 5 of 8
Hello SIr,
Good day! We would like to inquire for technical documents or manual for installing Web Server extensions and Several
Site Servers on different separate servers, also the configuration on how to load balance the multiple site servers.
Thank you very much.
Message 6 of 8
Daniel.Du
This site should be helpful:
http://sandbox.mapguide.com
especially this page for load banlancing
http://sandbox.mapguide.com/index.php/Pragmatic_Load_Balancing
Daniel Du
Message 7 of 8
in reply to: Daniel.Du
Sir,
Good day! We have already done what is written on the following:
but unfortunately load balancing does not work, the load is only focused on one server. Maybe you have
some further details.
Thank you.
Message 8 of 8
Hello Sir,
Good day! We would also like to know the proper server sizing for AIMS 2013 in terms of single server (Web and MapServer on one machine) and also for separate server setup, in pragmatic mode.
Thank you.
