I have a small problem with IIS configuration for use with mapguide.
I first confirms that it works if I run the mapguide server apache.
With IIS the problem is with windows authentication. If I enable this authentication, I can not manage to connect to MapAgent aa studio or because authentication is identical with that of mapguide and windows.
If I deactivated this authentication then I can have anymore access the site mapguide 2010 because it gives me "Access error".
Thank you for your help if you have already encountered this problem.
