Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
How to use Fusion API for creating points layer
0 REPLIES 0
Message 1 of 1
swimming123
560 Views, 0 Replies
How to create points in the client side by input lonlat values? I try use following code:
           var mgApiMapWidgetId = 'Map';
            var MainFusionWindow = GetFusionWindow();
            var pointsLayer = MainFusionWindow.OpenLayers;
            var Fusion = MainFusionWindow.Fusion;
            var mapWidget = Fusion.getWidgetById(mgApiMapWidgetId);
            var map = Fusion.getWidgetById(mgApiMapWidgetId).oMapOL;
            alert("a");
            pointsLayer.LonLat.fromString("51.2356, -114.235689");
            alert("aa");
            map.addLayers([pointsLayer]);
            alert("aaa");
It can alert to "aa". That means last step not success. Do I need add SRS from the current map? Thank you.
0 REPLIES 0
