Iam having trouble with the King FDO provider. using Fdo2fdo or FdoToolbox when i export point feastures classes from Oracle to SDF files the coordinates changes on several of the points. When I export from Map 3D 2013 using the commerical Oracle Provider i dont have the issue.
I need a way to batch create SDF's at night from Oracle. How can these be created using Infrastructure Map Server 2012? If I create a simple map with one layer that contains a point feature class can i dump the entire contents of that layer to an SDF file? That would be ideal.
