You can use the API to query they feature source while applying a filter to
get the featID of the polygon you want. Then, use that featID as the basis
to add your object to a selection object and then save that selection object
to the server. Then, refresh your map and the selection will appear.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
wrote in message news:5576254@discussion.autodesk.com...
I want to Highlight polygon object
how to get polygon in layer??????
