Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Google Message inside Mobile Viewer - General Google Maps overlay
5 REPLIES 5
wilsonherrera
2235 Views, 5 Replies
Hello everyone.
i am experiencing a trouble with a message from google maps everytime i interact or load  a google maps basemap.
if i zoom, the message appears, if i move, the same issue.
this happens with AIMS 2013 bot in mobile and desktop web clients.
is there a fix for this?
thank you for your Help
W. Herrera
5 REPLIES 5
jackie.ng
in reply to: wilsonherrera
Assuming that viewer is using OpenLayers 2.11, just patch the library like so:
https://github.com/openlayers/openlayers/commit/92f04a7a4277a6c818ef2d40a2856910ed72d3d6
or like this
http://trac.osgeo.org/openlayers/wiki/Release/2.11/GoogleMaps37
- Jackie
gluckett
thanks for the quick response! the fastest way to fix this problem was with the solution Gordon Posted.
after a while i tested Jackie solution and this also works!.
thank you very much.
Wilson H
katonat
Hello Everyone,
The solution works well on IMS2013 desktop environment, but I cannot remove the google popup window from MobileViewer Extension.
Someone does it work?
Thanks for advance,
Tamas
jackie.ng
in reply to: katonat
It's probably using its own version of OpenLayers that needs to have the same patch applied
- Jackie
