I use AIMS2013. One wierd issue with WMS Services is: In specific area, there's always show a gap in the WMS images no matter what scale is. If I create a pdf based on this location, the gap is not exist.It means the gap is not exist actually. Anyone has idea ? See attached image. Thx.
It looks due to the project on fly: source coords is different with my map coords(see wms_error1). So I try to set the coordinates in data connection(see wms_error2), then the whole WMS image disappear. Is this a bug with AIMS?
Finally the issue location: AIMS reprojection problem. This gap will always shows and it is locationed in the central meridian if you let AIMS to project WMS images on the fly. The only thing I can do now is use the same coordinates with WMS server provider. Just like the above attached image(wms_error1.png). I wish Autodesk developer people can solve this issue. Thanks.
