Infrastructure Map Server General
Distinguished Contributor
Robert_Fritz
Message 1 of 3 (174 Views)
Fusion settings - what will happen when I install the next release?
174 Views, 2 Replies
01-31-2012 06:19 AM
what will happen to all my settings and changes I have applied in Studio to fusion weblayout when I install the next release of MapGuide/AIMS? Will I loose any of those? Or all settings saved in the repository?
I haven't yet started but before I do I would like to know what to expect when I do an update.
With programming I assume all changes are lost if changes are made in existing files but should still be around when I create new files. Is that correct?
What are your experiences with frequent new product releases? Is the update process painless? Does it depend on how much you have configured your weblayout?
Many thanks,
Rob
http://raumpatrouille3d.blogspot.ch/
Valued Mentor
Message 2 of 3 (169 Views)
Re: Fusion settings - what will happen when I install the next release?
01-31-2012 05:48 PM in reply to: Robert_Fritz
Nothing.
Your data/layers/maps/settings will stay as they were, untouched in the repository until you write/modify/delete them with Studio or the MapGuide API.
Each version of MapGuide/AIMS installs to their own folder anyway, with their own separate repository, so it's not as though your applications and data will be trampled over by a new MapGuide/AIMS installation
Same thing applies to any code you've written. But really, you should be using source control (svn/git/etc) for your code, like any professional software developer should, so this is a moot point.
MapGuide/AIMS upgrades generally follow this pattern:
 1. Package/Backup current data and applications
 2. Uninstall/Disable old release
 3. Install new release
 4. Restore data and applications to new installation
It's very hard to trash your data and applications in a way that is not of your own doing.
- Jackie
Robert_Fritz
Message 3 of 3 (165 Views)
01-31-2012 10:16 PM in reply to: jackie.ng
Hi Jackie,
many thanks for your reply,
Rob
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
